Finally got round to fitting the kit last weekend.
Firstly, I got a bill for £48.15 from Parcel Force for VAT, Import Duty and their fu*#ing admin charge!!
But to be honest, that is the only gripe I have.
The instructions are very easy to follow and so long as you have the correct tools, i.e. 8mm torx wrench, cross head screwdriver and Stanley knife, no worries.
One thing though, you MUST follow the following procedure to disconnect the battery, otherwise you will set off the alarm and pretty much deafen yourself, as I did, fortunately, I have a good contact at OPC Nottingham who told me what to do.
Turn the ignition on, then disconnect the NEGATIVE terminal of the battery, then the alarm will not go off. DO NOT try to do this without having the ignition on, do this at your own peril of hearing loss!!! Also, make sure it is the negative terminal cos when you reconnect (making sure the key is in the ignition and turned to the ON position) there is no likelyhood of a spark (which there is if you do it with the positive terminal).
The speakers are very good for their size, but you may want to cut some of the bass out when you are listening at speed and trying to get the best out of them as with all speakers, the head unit can drive them harder than they really want.
Very neat and tidy installation and I strongly recommend them.
If you want any pics of the finished product, let me know.
Phil
