Boxster Sports Exhaust
- Thread starter bdheng
Mather
ORIGINAL: bdheng
Has anyone any experience of this exhaust for 986's
Seems remarkably cheap at £269 - about half the cost of other suppliers
http://www.ebay.co.uk/itm/STAINLESS-STEEL-PORSCHE-986-BOXSTER-EXHAUST-BACK-BOX-/110729122712?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19c7f85398
pjwakefield
Mather
ORIGINAL: pjwakefield
hi have you fitted it ? what's it like any vids? thanks
ronald smith
Like to know how fitting has gone.
Ron
Mather
Fitted the exhaust with my mate Carl who has a garage and a ramp, did not need to remove rear bumper just unbolt the double clamps and push back towards the back cats,then unbolt the top mounting bolts.It was about three times heaver than the new one.Carl fitted the new one he said he did not have problems he just had to play around to centerer the tails.On my first boxster i did a kettle exhaust mod IE, fit (weld) two stainless pipes in front of the silencer then bent round the silencer and cut and welded to the tail.The sound this made was like stock up to 4000 revs then just a little louder but you could only hear it in first and second gear.This toyo performance Exhaust is very different on start up it has a deep base sound not as bad as a subaru a more sporty sound (flat six)It seemed a little too loud at first but over the week it seams to have settled down.One thing i will change is that on the stock exhaust porsche have a rubber mounted bolt system to stop vibrations from the exhaust droning in to the cab, i will be fitting rubber washers between the mounting clamp and bottom of the gearbox.Overall i am happy with the exhaust it sounds like the new boxster even a little burble on the over run,will try to post video if it ever stops raining []
(in reply to pjwakefield)
sbloxxy
Any thoughts?
Nice burble when started - and good sound above 3000rpm.
However 2000-3000 there's unbelievable droning.
Now, gone back to original box.
With regard to cats - thats where emissions are controlled, I believe. It is possible to change to 200 cell cat, but 100 cell are borderline for MOT limits.
Me - back to the drawing board ................
ORIGINAL: bdheng
I fitted my rear box a couple of weeks ago, and followed Ken's advice with additonal rubber mounts.
Sorry I missed this post as I could have cautioned you about the terrible drone between 2500-3200 rpm I experienced when playing around in the past with bespoke custom made systems
I once had the pleasure of a chance meeting with the 986 head of design at Goodwood Festival of Speed and he advised me that the exhaust system on the 986 was very complex and playing around with it could cause many headaches. Sadly I didn't listen and his words proved right and I would add driving other 986's my car with the non standard system definitely felt down on power too [&o]
I should add had far more success on all fronts when I converted my boxes on my 987 S using the expertise of Carnewal http://www.carnewal.com/ who know there Porsche stuff and are extremely helpful too
P86 "GT" Exhaust
The GT exhaust is a reworked original exhaust, modified in our workshop. From the outside, it looks just like stock but the internals are changed to a better breathing, less restrictive exhaust.
The result is a louder and deeper sound with no reasonance.
This exhaust does not trigger check engine lights does not give you any problems during the yearly technical inspection.
This exhaust is internally modified !
No plumbing tubes on the outside....
http://youtu.be/JzkjZHOArbE
ORIGINAL: bdheng
Daro911
Just noticed your comment about Carnewal - totally agree but he hasn't done 986's for a while now. He was my first port of call some months ago.
Isn't it only a case of not not doing them, but rather you have to send him your exhaust to work on because he can't get original ones any more?
Mather
Cheers Ken
p.s. on the 2.7 boxster the bypass tubes were fitted on boxster s exhaust which i got from Douglas Vally breakers 50 pounds good luck
ORIGINAL: bdheng
Daro911
He's still doing 986's. Went to Belgium and had mine done in July. Very pleased with the results.
Steve
