Boxter spoiler sticking
- Thread starter Guest
thboxster
The fact that it's gone down now might suggest that there isn't an issue. I would recommend NOT trying to manually push it down but turn on the ignition and use the overide button. (986 in drivers footwell / 987 on centre console).
Try manually (with the button) raising it then lowering it a couple of times to see if it seems to work.
If you find you've parked the car after moving it and the spoiler is still up, on a 986 it usually means that you've accidentally hit the overide button with your foot.
It was under warranty at the time to I took it into Porsche Centre Reading.
They had a look- couldn't find anything wrong
They swapped in a different spoiler- didn't work
They returned the original spoiler- and it started working again.
They didn't know what was wrong either.
Maybe its upset because you've missed an S !
