sawood12
Just reading an article on brake balance where it said that manufacturers achieve the desired brake balance by the relative sizing of the calipers front to rear. Alot of people are running uprated brakes up front which would upset this balance and I was wondering if many people had noticed much of a difference when upgrading to bigger brakes up front. Or does the 944 have another method of achiving brake balance which means its not sentitive to the realive size of the calipers?
I have been considering upgrading my brakes using BoxterS/996 calipers which seem to be cheaper and more readily available than the big reds/blacks and wondered about replacing the calipers all round to maintain brake balance and the asthetics of having the same type of caliper on the rear - also you irradicate the caliperplate problem.
