Brake Bulb
s2rjn
Can someone please recommend the correct bulb for my left rear brake light
The warning came on today
It seems very easy to change and I've looked at the Halfords & Design 911 site but I can't seem to find the correct one
Thanks in advance
Rich
Assuming this is a Gen 1 car then I think it's a standard twin filament 21/5w bulb. Can't you take it out and have a look at what's stamped on it?
http://my-car-bulbs.co.uk/porsche-911-(997)-2005-
Thanks tscaptain (yes gen 1)
I have just removed it and it says 21/4w
I have a 21/5w can I use that or do I have to have the 4w?
It would probably be better to have two the same, either 4 or 5w, or one side light will be a bit brighter than the other! Depends how OCD you are![;)]
Bayonets on the bulb are staggered for correct fitting, but it's still possible to fit them incorrectly, which means you end up with a 21w taillight and a 4w stoplight. So get someone to help you check them before you drive off.
Regards,
Clive.
