Where's the best place to get new caliper piston seals?
I recently acquired a set of used 944 front calipers on E-Bay as part of a serious brake upgrade for a VW Camper, but the rubber has seen better days. The calipers are Ate steel single pot ones off an '86 944 with a piston inner recess bore of 39mm and outer lip diameter of 54mm. I believe the seal kit part number is 928 351 941 00.
Also, I am looking for a pair of 944 (non turbo) rear discs with the handbrake operated drum brake assembly.
Any advice much appreciated!
Cheers, Alex
Cheers, Alex
