Brake Calipers
- Thread starter rooksy
Then undo the brake line at the calliper. Turn the steering wheel so you get the best access to the back of the calliper. Use either a ring spanner or quality socket & ratchet (19mm bolt I think). Undo. It will need plenty of force but apart from using an air wrench there is no other way.
When you refit the bolts use a dab of copper grease on the threads to make the job easier next time.
DBA
New ones were very reasonable from my OPC (£7 I think) but had to wait for delivery from reading.
I then refurbished the caliper (Kits available for about £14), but am now terrified that I might not have done it properly, and the caliper might fail under heavy braking. I plan to get it refurbished professionally.
DBA
3.2 Carrera Cab in Cassis
rooksy
Sean
DBA
In summary, this is what I did, but please read the instructions and don't proceed unless you are happy with what you are doing - the pressures involved are large and potentially damaging.
To begin with I had to get the piston out of the caliper. Books, like the haynes manual talk about using an airline, I tried, but this was not going to do the job (couldn't get a good seal) so I reverted to using the braking system itself to push the caliper out. This is a two person job, as someone needs to shout when the piston is about to pop out.
Having removed the piston, check it for corrosion - and if corroded disgard it - mine was OK. I replaced the rubber seal within the caliper, lubricated it with some fresh brake fluid and replaced the piston. This was a difficult task, and broke my caliper compressing tool in the process. I refitted the dust cover and retaining clip, and that was it.
However what I cannot do (don't have the tools) is pressure test it - if you get it done professionally they do. So although it seems ok, I am now paranoid that they will fail under heavy braking so I am going to send them to the professionals for them to refurbish. I believe they also replace the pistons.
DBA
3.2 Carrera Cab
rooksy
Sean
rooksy
I've contacted my local OPC to get a price and check if they had any pads in stock, and they advised my that I will have to replace the sensor on the pads they will sell me.
Sean
