Brake Callipers
I have a 993 C2S with black brake callipers. The paint finish is in good condition but I would like to change the callipers colour to red, like the C4S and the turbo models.
Has anybody done this? If not, can anyone suggest how this could be done or reccomend a company that will do this?
Many Thanks
Gary
Gary - it can be done, as my 986 had the colour of the calipers changed to red before I bought it. I am not sure how mine were done - probably sprayed. A heat resistant paint must be used and be aware that any 'porsche' decals currently on them will get lost in the process. If you are up to doing it yourself try this link from eBay - he sells the paint (red/yellow or black) and heat-proof decals as a kit for <£20:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=10408&item=4555716135&rd=1
Good luck with it and let us know how it goes - I want to redo mine too!
you can get it done professionally but it can cost.. but my local indep garage admitted that they just use the £20 paints from halfords when they do it.. and charge £250 ![:eek:]
so I curenntly have the calliper paint set..... some decals to go on top and I'm just awaiting for the right time !
Hi Russ
Thanks for the ebay hyperlink. I have just purchased decals and will let you know how it goes (however, it will be ages until I actually get round to it). Fingers crossed.
Gary [:)]
I completed the change from black to red on my car calipers over the winter,,
bought the transfers from e.bay,, £10 for 6,,,,,,and the red halfords paint,,, about £20,,,
I took all four calipers off, took out all the pads and cleaned the calipers till shiny, inside and out,, then sanded them down to get rid of the chips in the old black paint and finished sanding off with smooth emery,,,, masked the seals of the pistons, and took out the bleed screws... and put masking tape inside them also..
takes two coats of red,, on each caliper,, one pack from halfords did all four calipers with spare paint left,,, but because the paint sets quick quickly,, to a nice goo,,, I mixed it up in small batches,,, 8 batches in fact,,,, managed to save the brush most of the time,, by cleaning it with thinners,, left calipers for 24hrs to harden,, refitted with new pads, and fitted calipers,, re-bled etc,, which is quick to do,,, then once that was all finished fitted the stickers,,,,,,,,,I thought it best to fit them once the claipers were on,, less chance of scraping them,, or getting, brake fluid on them,,,,
they look like new and you could not tell them apart from originals,,,,,, thought they might go dark red with heat,,, car little used,, but has been to outlon park and knockhill,, and they are still shiny shiny red,,,,, stickers are still white and have not come off at all...
took me about 40hrs,, in total to complete the above,,, bit of an anorak,,,, but worth the effort,,, if I could figure out how to attach photo,, could show them fitted,,, if you want to see some photos,, let me know and I will e.mail them to you...
car is silver,, and looks much better with the red calipers than the black,.,,,,,
cheers
scott,,
Cheers Scott
Sorry, haven't been online for a while but have just got your message. Thanks for the advise and the breakdown of how you painted your callipers. It is much appreciated. I'll definitely try this and will let you know how I get on.
Gary [:)]
had mine powder coated red from a local paint specialist, they shot blasted them clean, then powder coated them, baked them in an oven at 200°C for an hour. £75 the four. Bought the Porsche transfers from WWW.caliperdecals.com, £12 for six, fitted them and coated with a high temperture lacquer spray from Halfords to protect them, fitted the caliphers back onto the car, thoughly bled through and changed the brake and clutch fluid at the same time.
