plhorner
Moderator
Not content with fitting a new exhaust system to the car, I've just started on a brake re-fresh. I'm fitting new flexible hoses (braded stainless), new front pads and re-building all the calipers. As per usual, the job is snowballing, the calipers have been a b1tch to strip and I'm not sure if one of them is salvageable!! Anyway, 'whilst I'm in there', I thought I'd remove the brake shields and get them bead blasted and re-painted just to clean things up. So I start at the FNS and try to take the disc off so I can get to the heat shield, I can't remove the cap to get at the wheel bearing adjuster. Plenty of WD40, a good tap with a hammer and drift and still the damn thing won't shift - both sides the same. Anybody else suffered with the same problem, any bright ideas?
