Brake Discs
Manxviking
My OPC commented that my brake discs were dirty and needed to be re-drilled. Is this an easy task and what sort of equipment do i need?
All you need is a bicycle spoke & an airgun (well they're my weapons of choice). They are just cleaning out brake dust from the drilled vent holes in the disc....just out of interest how much are they charging ?
They quoted £250 which I politely declined. The cost of the major service and the 2 yr extended warranty had already caused enough damage to the bank balance!
The face of the disc tends to get tiny cracks, radiating from the holes if they are blocked up and worked hard (tends to be worse on GT3's). Just worth giving them a poke through now & again if you're really bored [:D] & a lot cheaper!
A screwdriver that just fits through the holes also works. Rotate the wheel as you do it and the dirt falls out.
My OPC was quite a bit cheaper at £100 whilst in for service..
I didn't have it done in the end which turned out to be a good thing as the discs are now worn to the point of needing replacement [;)]
garyw
