Torrential rain in Cheltenham so thought I'd ask here rather than lying on my back on the driveway...
Most brake ducts I've seen have a visible screw holding them in - mine don't. Do you think they're screwed in from behind? Des, can you remember how they were fitted or were they fitted before you owned the car?
Also, need to remove the indicator housing and the 'blank' next to it.
The 'blank' just has a simple screw at the outer end and it comes off by unslotting the tabs at the inner end. The indicator housing also has a screw at the outer end (revealed when the blank is removed), but how is it fixed at the inner end next to the duct? No visible screws or other fittings.
Cheers. []
Cheers. []
