Brake Fluid
- Thread starter 964RS
Completely agree, I tried dot 5.1 (generic & branded) after my brakes overheated at my first trackday, they still boiled just the same. Now use Racing Blue & haven't boiled it since, it's no longer the weakest link, and I've had no problems (that I wouldn;t otherwise have had) with the fluid in normal use either. Then I started to get a hard 'dead' pedal from heatsoak (pads/disk too hot), added the early turbo brake ducts & they no longer overheat at all. Standard pads (so far) too [ORIGINAL: 964RS Use ATE Super Blue racing. DOT 4. It's excellent on the track. []
It should last about a year, yes.ORIGINAL: AntB So this stuff is good for normal road use also and normal regular change intervals?
But I just wondered what you guys used??... I guess the more common is DOT 4... When I ran my very modded Saab 9000 which had yellow stuff pads and brembo disks - I changed the fluid to DOT5.1 (dont use DOT 5!) and the brake feel straight away was MUCH better on track and road use.
Just wondered if anyone has used DOT5.1 in there 944 and how much better it was over DOT4?
Cheers A
Peter Empson
Same here, I boil the ATE fluid, but SRF is fine (I think it still boils/overflows slightly, but the pedal stays firm). I'm led to believe it is quite hygroscopic, so a yearly change is recommended (or more regularly if you race of course). I used to use Castrol Response (a cheaper option) and that was good too, but not in the same league as SRF.ORIGINAL: eastendr Castrol SRF ....
tr7v8
Hilux
True 5.1 is hygroscopic (absorbs water) so needs changing every year. ATE blue or SRF if tracking the carNo need to buy anything expensive for road use - any dot 4 should be fine
Hilux
Its not [8|][8|] its a typo, sorry - Note to self: must not rush type when replyingDot 4 is hygroscopic, didn't know dot 5.1 was as well
944 man
You were right originally: DOT5.1 fluid IS hygroscopic. DOT5 is silicone based and it isnt hygroscopic, but it isnt compatible with cars previously run using mineral fluids.ORIGINAL: HiluxIts not [8|][8|] its a typo, sorry - Note to self: must not rush type when replyingDot 4 is hygroscopic, didn't know dot 5.1 was as well
