Brake fluid
- Thread starter roygarth
Steve Brookes
Moderator
Brakes in the RS are so damned good you could fill them up with water! []
Steve Brookes
Moderator
ORIGINAL: roygarth
Thanks Steve, are there any drawbacks with a higher boiling point Dot4? Car is mainly used for 15 minute thrash to work on B/C roads. I'm unsure of age of fluid currently in car so was plannning to flush it out and start again - is that a good plan?
I would say no there aren't any drawbacks except for it being slightly more expensive. Even then, the castrol stuff I mentioned is only about £10 per litre (from Demontweeks). There are no problems with mixing this with what is already in. What you should avoid (and I'm hoping I'm not trying to teach you suck eggs) is adding Dot5 because that doesn't mix (Dot4 is glycol based and Dot5 is silicone based).
I agree it's a good call to flush it out. I now do a complete flush once a year and bleed a little off (and just top up) after each trackday.
