Paul Fraser
OK, bear with me on this one.
Car failed MOT today because of (among one or two others): "offisde front brake juddering severely" (this giving a 36% imbalance). Examiner said that the disc was warped/corroded.
Got home, wheel off, caliper off, looked at the disc, gave it a spin and it seemed fine to me: no particular corrosion other than some pitting/edging and it didn't seem to be warped (looked fine from above, spinning).
Tried freeing off the caliper, as I thought this might be the problem, also put new brake pad pins in (too let them move freely if required, old ones were rusted) and also greased the grooves the floating part of the caliper move on.
Out for a spin and there is still marked judder braking from 70 to 60 and at maximum braking the left hand wheel locks up and the right hand one doesn't.
Now... have new discs and pads I can fit and will happily do so, but is there anything else that could be causing this before I do, rubber brake hose for instance?
Thanks.
P.S. Advisory for slight play in steering rack.
Thanks.
