Brake life
- Thread starter johnk
paulfcraven
PCCBS do not use ceramic pads as standard they use a Pagid P40 variant. Ceramic pads on ceramic discs tend to be very noisy and too hard wearing on the discs and are therefore not advisable.The reason why you get less brake dust is because the brake pad abrasion is a lot lower due to the hardness of the ceramic coating on the disc.ORIGINAL: dyllan it is true,but an expensive way to keep the wheels clean[] its because the pads do not contain steel but are ceramic and copper-they do give off dust but it is light and doesnt stick to alloys but flies off )and therefore is much less visible)
Monty2
paulfcraven
pagid p40`s are one of the pads used ,but there are many others out there with different composites-the fundamental similarity is i believe ,the absence of steelPCCBS do not use ceramic pads as standard they use a Pagid P40 variant
