Justin85
Having just fnished replacing the rusty and leaking sections of fuel pipe (over the rear beam) with synthetic braided hoses I was somewhat dismayed to discover that there is also a leak from the brake pipes. There appears to be a pinhole leak from one of lines that comes away from the "tee" which splits the line between right and left. It's damp, and when you depress the brake pedal a stream of fluid squirts out.
Having just changed the fuel lines without having to lower the rear beam, is there a way the brake pipes could be done similarly or is it definatly a beam off job?
How much would I be looking at at an indy to have the lines changed? The previsous owner had Goodridge braided hoses fitted 2 years ago, so these are okay.
Many thanks for your help.
Justin.
Justin.
