brake pad advice
- Thread starter speed
GreigM
Brembo as supplied by OPC: Good all round, not too dusty, don't squeal, not too hard on discs, fade easily on track days - a good choice for road only cars - expensive
Textar: some say these are the Brembo OEM - same characteristics as above, some say harder on discs but I haven't experienced this. Cheaper than Brembos.
Pagid: varying compounds, tend to squeal a lot and produce a lot of dust. Outstanding on-track performance, very fade resistant,not so good when cold - good choice for track day pads, very expensive.
Performance Friction Carbon Metallic: As pagid, good track day, not quite so bad on road - squeal like a pig, lots of dust - I had the "97" compound which is best for cars with ABS.
EBC Greenstuff: Good reports as a road pad - less dust than standard. No use for trackdays - early fade.
I got to the point where I was swapping the pads for trackdays to the performance friction pads and back to the textar ones for standard road use.
