Craigybaby
Evening, had to go to cleethorpes today from Leeds. With 10 miles to go and cruising on the motorway, heard a massive bang, looked in the mirror and saw a rock sized object bouncing into the undergrowth. Straight away brake pad sensor warning light came on and started beeping. Tested the brakes and they seemed ok so carried on. Before setting off for home checked wheel nuts tight and all brakes looked ok. Brake pad light had gone out. Stopped for petrol and light came back on. What do you think is most likely explanation? I've just about discounted anything has fallen off the car, more likely a rock has damaged a brake pad sensor, although unusual to hit a rock on the motorway, and god knows how I didn't see it.
