Brake pads
- Thread starter xenon
DavidL
Presumably changing whole axles is the best option but would you usually change all 4 wheels?
No idea exactly which wheel is prung the sensor but I don't suppose it matters.
Will check the sensor wires first!
Also is there an issue moving a car under its own steam about 10 yards from stone cold if said car has no cooling system currently?
You got it - dead car in garage awaiting bits - need garage to do pads! Can push it out (downhill) not back up easily!
DavidL
ChasR
sawood12
DavidL
chrisg
sawood12
Don't get me wrong- it's not an emotional thing but it just strikes me as being the first thing people consider without actually considering OEM. I don't buy the moving on of technology thing - brake pads are brake pads - they are pretty well understood and unless you're going to carbon brakes then the technology hasn't really moved on for a few decades, it is what it is. It's a bit like baking, the various materials are blended to achieve specific characteristics and Porsche have worked very hard to find a recipe that works for a road going car without too many compromises and they do know more about brakes than most of the aftermarket brake companies. But I would say, don't mess about with aftermarket pads unless you have a specific requirement you're looking to fill (and most people don't). OEM pads are perfectly adequate for all but the most dedicated track day car or race car. Been there, done it, got stung and wished i'd stuck with OEM. I think alot of people step out of newer over-servo'd cars and into Porsches and the brakes feel very different and they assume something is wrong when often all that is required is a bit more effort on the brake pedal.ORIGINAL: DavidL Nothing wrong with modifying cars, we all do it. Technology moves on so why not consider alternatives? But everyone has an opinion, I was just casting about for them. Thanks for everyones' contribution. Nothing wrong with OEM at all, I don't think anyone was suggesting that necessarily. Clearly brake pads are an emotive subject.
