Brake pads
- Thread starter ianfiat
JCB..
Non-member
Blacks are the direct replacement [link=http://www.ebc-brakes-uk.co.uk/ebc-black.php]http://www.ebc-brakes-uk.co.uk/ebc-black.php[/link]ORIGINAL: Tony Daniel Reds are a direct replacement for the standard pads, yellows are for track use. The reds do not grind, squeek or anything else, they produce no dust so your wheels stay clean, and there is a special backing on them so you don't need to buy the anti-squeel pads required on the standard pads.
JCB..
Non-member
Better Red then dead! [ORIGINAL: Tony Daniel When you go through the order process it will tell you REDS are the direct replacement. [link=http://www.brakes4u.co.uk/supersearch.asp?step3=yes&catType=C&catParent=1&pMake=PORSCHE]EBC web link[/link]
JCB..
Non-member
Me and Mark did Nic's for him with no real problems! [ORIGINAL: ianfiat Are there any pitfalls to changing them myself ? There is another post one here of somebody who used an Indy to change pads and discs and ended up going to an indy to have the ABS light switched off.
