Hi
My car is in need of brake pipe replacement as the current ones are badly corroded. I understand that there is one pipe that needs to go over the gearbox and as a consequence the engine needs to be dropped in order to replace it.
I read somewhere that someone had come up with a solution which uses a flexible pipe which can be installed without dropping the engine.
I cannot remember where I read it, has anybody seen it and point me to the right direction?
David
David
