I have been mulling over the options for replacing my brake pipes which are starting to show signs of corrosion - not serious but but will need doing in due course. Having read a wealth of info via google it seems opinion is evenly spread between 'avoid copper at all costs and copper allloy is the best'. Any thoughts amongst the 996 techno wizards.
Also Brake fluid - clearly DOT 4 (any specific DOT 4?) should be used but again it appears from google search that DOT 5 synthetic is perfectly OK but difficult to get out all the air when bleeding = spongy pedal. Again any thoughts out there.
[8|]
[8|]
