Brake pipes.
- Thread starter blade7
I'm looking for the short hard pipes that connect the front brake calipers to the rubber hoses. I don't see them from any of the UK suppliers, and I expect Porsche would bend me over for them. Nearest Pirtek is miles away, so any other suggestions?
Porsche ones are about £50 each looking at PET.
Where are you located? If you were close to Worcester, I could have made you a couple from your existing ones.
blade7
Well-known member
Thanks for the offer, but I'm located near to Boston. I'll ask the garage that did my MOT if they know anyone local that could make some. I'd bought a pair of Pagid hoses that aren't a match the hard pipes, but do fit the calipers. But I read that short copper pipe cools the brake fluid?Porsche ones are about £50 each looking at PET.
That’s what I have doneThanks. I think another option could be to use one of the braided hose kits, that connect directly to the caliper/
blade7
Well-known member
How are the rubber hoses working, I ordered some rubber Pagid hoses from Halfords. But they connect straight into the caliper, rather than to the hard pipe. I was going to return them, but they were only £11 each.My Goodridge braided flexi's seized solid in my calipers after about 4 years, and couldn't be removed. Had to cut them to remove the calipers when we were swapping them over. I've probably just been unlucky. I've went for a set of standard rubber ones for the time being.
scam75
Well-known member
Yeah they are not expensive. I can't answer that yet as I haven't driven the car since the new brake set-up went on, waiting on a strut coming back from GAZ.
I should be able to let you know later in the week.
IIRC i've never seen those little hard pipes on my car. It had rubber flexi's straight to the caliper when I bought it before I changed to braided.
Stuart
Stuart
scam75
Well-known member
Yes, that sounds correct and would make sense. I think I prefer the feel of the pedal now I've driven it more.Good, as I've fitted the rubber hoses now, so can't return them. I read something years ago that said good condition rubber hoses gave a slight cushioning effect if you jumped on the brakes suddenly, whereas braided didn't have any give.
blade7
Well-known member
I can't seem to find a free version of PET online, have Porsche clamped down on this?Porsche ones are about £50 each looking at PET.
AndrewCS
![www.porsche.com](https://files.porsche.com/filestore/image/multimedia/none/classic-genuineparts-originalpartscatalogue-xle/normal/7649fc6d-8113-11e4-9265-001a64c55f5c/porsche-normal.jpg)
Porsche Classic Genuine Parts Catalogue - Porsche Great Britain
The fascination of Porsche is timeless. How can you tell? Because more than two thirds of all the Porsche vehicles ever built are still on the road...
![www.porsche.com](https://files.porsche.com/images/mobil/icon/porsche_57.png)
In line with the industry`s & dealers` current convention of crap communication they`ve taken to burying it further ...
