Hi,
Manual says "C4, C4S and Turbo: Brake pressure is monitored in addition to fluid level....you should not drive off until the pressure has built up....." etc.
I've never notice the light before but now it's on most mornings. Admittedly only for a few seconds (while I ignore it and reverse out of drive).
Also had the ABS light come on two occassions when I started up (with the above light). That did not go out until I switched off and restarted.
Anyone else seen this (or had to do anything to fix it long term)?
