Brake problem
- Thread starter samp5679
The pistons will be operating on a different part of the caliper, as the new pads and disk thicknesses will push then further in. It might also be that the new pads are tight in the slot in the caliper, but whoever fitted them should have noticed that.
If it doesn't improve within a couple of hundred miles, I think I would consider getting the calipers refurbed. A brake fluid change might help, but I don't really think it would help, unless it is very long overdue.
Did he suggest how the water could get there ?
If the bellows are torn / not fitted correctly, water could get in again & could be sucked inside the servo - causing it to return slowly & to internally rust / fail eventually.
If that is the cause the servo needs removing / emptying of water - but the corrosion could well be underway
(Ford Fiestas used to suffer from a similar problem because the drain from the scuttle was directly above the bellows - which were not sealed)
PS Just seen Richard beat to a similar reply !!
Paul
2004 C2 996 40th Anniversary
