plhorner
Moderator
Just finishing off the brake re-fresh tonight and I've run into problems I think!!!!
I blead the brakes through using a pressure bleader (which I incidently built myself for £3) and I reckon I've got all the air out of the system, the fluid is running clear and bubble free. First press of the pedal and it sinks a little way, I assumed bedding the pads to the disc and it then firms up on subesquent applications. Anyway, 5 minutes later, press the pedal and it again sinks half way down before firming up on subsequent strokes. Have I either still got air in the system or alternatively a kanckered master cylinder? Incidently, the master cylinder was fine before I stripped the calipers and I've not disturbed it in anyway as part of the work, save for replenishing the fluid [8|]
ANy bright ideas?
I seem to remember somebody in the dim and distant past mentioning a similar problem but can't find the thread.
ANy bright ideas?
