Brake replacement
- Thread starter ArBee
example:
Column stalk failure on the 996 is quite commom. My indie has seen a couple, so much so that he buys in the obc and cruise control version and takes the obc stalk off because it is cheaper than buying the cruise version.
I told him the cheapest way was to buy the basic switch and refit the obc for the ultimate saving.
Right price wise; OPC £87 with discount plus vat came to £97 odd. I didn't bother with Type 911 becasue you have to get a quote, but design 911 was £117 delivered, and I can assure you that I did not use £20 worth of juice collecting it. If you can make similar savings on the brakes you would completey offset membership.
Other outlets are Bert Gear used to be BerLyn parts but now I think they can be found as Parts for Porsche. It is generally accpeted that Porcheshop is one of the most expensive places to buy parts from, do check out eurocarparts they often have good deals going, only recently they had an exceptional deal on 944 discs I think
T911UK
http://type911shop.co.uk/shop/article_5429/996-Steering-Column-Switch.html?sessid=va5JYaP6yJOxI8whkCx0az8dYxY5eCKCiKesu3jrcxcUVNEmZwfCGsuSOlo0ErLk&shop_param=cid%3D351%26aid%3D5429%26
Photo, description, price, manufacturer, availability.......
Ok Maybe I have missed a link somewhere. I clicked on 944 parts and directed to a phone number.ORIGINAL: T911UK
While I agree with you 100% about sites with POA on them, I dont know what more info you could ask for in our listing of that said part;
I've used design911.com and carparts911.co.uk (aka eurocarparts.co.uk) and last time bought Sebro discs and Textar pads.
Don't forget anti-squeal shims if you're not going to reuse them, and sensors too if they've triggered. Or melted.
