Brake Squeaking
- Thread starter COF139
dereksharpuk
dereksharpuk
Mine too was Gen II PDK.
Porsche admitted the fault on some other 911s
Mine does it in reverse ( although I have Pagid pads not OEM) It will be the pads without anti squeal shims doing it. For the life of me I can'tORIGINAL: COF139
The brakes are metal.
The squealing is horrendous when reversing. Don't get much of an issue at all with braking in the right direction !
remember if that's front or rear, atm! If they are fine going forwards I wouldn't worry.
If all this checks out, look at the handbrake mechanism for potential binding.
Regards,
Clive.
dereksharpuk
When I mentioned this to the OPC, they did acknowledge that others had referred the same issue and did suggest they could clean everything out (as per the advice from Clive), although they did suggest that this would only be a temporary fix so it would come back. Obviously not considered a warranty item, so I didn't ask them to do any of the work !
