Brake upgrade
- Thread starter Bungditin
What are your concerns with your standard brakes as I never felt mine were a problem as a road car (with the larger rear callipers) and I drove it in a spirited manner ?
Dekker
If yours is a C4 then you only need the front brakes upgrading.
Upgrade to 924 S4 fronts on Sports 928 S4 discs
• front calipers (require caliper adaptor)
• 302 x 32mm cross-drilled front discs for 928 S4
• 993/964 Carrera RS rear calipers (they are the same caliper)
• 964 Carrera RS cross drilled rear discs
• Recommended: 993 master cylinder for C2. For track use, RS upgrade for C4, Turbo
• 55 bar bias valve
This upgrade further enhances brake cooling with a larger disc. By themselves, the front calipers would increase front brake bias, however, this is balanced by fitting the 993 calipers with larger pistons in the rear. Discs now have holes and curved, directional, vanes in the front. This upgrade requires 17 inch wheels.
Front
2x44mm Seals
3x36mm Seals
Rear
4x34mm Seals
4x30mm Seals
Brakes International 01706 662986 Josh Without pistons £63.95
2x 44mm kits (piston & seals) OPC Sutton Coldfield
1x 36mm kit (piston & seals) OPC Sutton Coldfield £69.61
2x caliper interconnect pipes & fittings £6
5mm ID Samco Silicone Hose for interconnects 1metre RaceBikeBitz £4.50
2x brake pipes & fittings £6
2x Adapter Brackets for fronts £50 Pro9
4x M12 x 1.5P x 35mm fine pitch Allen cap head bolts High Tensile Grade 12.9. Ballsgrinding.com £8.58
4x M12 x 1.75P x 80mm fine pitch Allen cap head bolts High Tensile Grade 12.9
Kay's Fasteners £3.94
8x M12 washers for 928S4 calipers OPC Sutton Coldfield £2.50
55psi regulator valve OPC Sutton Coldfield £61.58
993 C2 rear calipers £150 PCGB member
928S4 front calipers £130 Ebay
2x 964RS front discs Pro9 £350.40
2x 964 rear sports discs CarParts4Less.com £175.56
Total £1,102.62
964 C4 Textar rear pads
928S4 Textar front pads
Prices were for 2014/15
Dekker said:I upgraded mine using 2nd hand 928 S4 calipers for the fronts and 993 rear calipers. There are articles on Rennlist showing what's needed and what you can do. If you want to go brand new the Big Reds for the fronts but you'll need the larger discs, 330mm, as opposed to the smaller ones I used for mine which are the same as 964 RS.
• 55 bar bias valve
Front
2x44mm Seals
3x36mm Seals
Rear
4x34mm Seals
4x30mm Seals
Total £1,102.62
Hacki
Now that you mention a wooden brake feeling, better pads with a strong initial bite may solve your problem. The standard brake is absolutely fine for a road car.
Personally, I have good experiences with Performance Friction brake pads.
I found this link: https://www.design911.co.uk/fu/pt66_1642_-cma81-cmo107/Porsche/964--911--1989-94/Performance-Friction-Brakes/
It´s well worth a try before spending a shed-load of money on calipers, etc..
Track use will be a different story.
Hope this helps,
Hacki
Steve Brookes
Moderator
The wooden feel could also be associated to the state of the calipers. They may well be suffering from the classic 'spring plate lift' issue that affects these cars. Extensive plate lift (corrosion behind the plates) will mean that the pads are not moving freely in the calipers.
mcgc0
Stuck to Textar pads (as recommended by a current PCGB Speed Championship buddy) and only get these from an OPC. High/track quality brake fluid is changed religiously every other year. If you are to change to different calipers then it's an all wheel consideration and not just rears - the bias will throw you off into the scenery Let us know what you go with on the end...
Steve Brookes
Moderator
Bungditin said:Very helpful advice guys.
i guess I’m in the market for some 993 rear calipers
cheers
Not quite. The only 993 rear calipers you can fit to a 964 which has the normal front calipers are the ones from a 993C4. If you get the 993C2 rear calipers you will add so much rear braking bias that the rears will lock up before the fronts.
So your choice for 4 pot rear calipers are the rears from: 964C4, 993C4, 928S4 or 968 (and I think the 944 turbo). For the latter two the bleed nipples would be pointing down if you fit them as they are so you have swap the bleed nipples with the cross pipe before fitting.
Here's a write up and pictures of when I did the upgrade to the rear brakes on my C2:
http://boxsey.blogspot.co...ke-upgrade-jan-08.html
Steve Brookes
Moderator
mcgc0 said:Options options... you can go mad (just for the sake of it) and throw silly money at something you'll 99.9% never use as designed. To be honest, I thought I could improve things years back but 2 different C4's later I realised I'd just be wasting my time and money (which is better spent on top tyres and long EU trip fuel to Le Mans!). As mentioned above I believe, the C4 and Turbo have the same calipers as 928 S4 (big blacks) and different to the C2, it also has a high pressure hydraulic brake boost pump - a charged circuit ready to drop anchors in a millisecond on your command. Plus it has a different master cyl diameter. All in all, I find the braking to be phenomenal and really do the job well - track days and when I've spent 7 hours/day fast driving the Scottish open highlands with full/fast on braking.
Marcus, just to be sure, the C4 did not have big blacks all round. Only on the rear. The C2 had 2 pots on the rear until MY92 when it also got the 4 pot rears. The 3.3 turbo had bigger front calipers and the same size rear calipers but with bigger pistons (essentially the same brake calipers that were put on the 964RS and then the 993C2). Summary of all the brake calipers, pistons and disc sizes at the link below:
[link]https://members.rennlist.com/1976c38/brakes.htm[/url]
mcgc0
Steve Brookes said:...the C4 did not have big blacks all round. Only on the rear. The C2 had 2 pots on the rear until MY92
That's right Steve, apologies if it wasn't clear as I thought it was the rears we were referring to. Yes, later year C2's were upgraded.
Also correct is the suggestion the 944 T's had same calipers - the final MY 944T's had a lot of juicy performance options as standard (inc M220 LSD etc).
Still thrashing the Cayman R (or even still have it?)
Steve Brookes
Moderator
mcgc0 said:Steve Brookes said:...the C4 did not have big blacks all round. Only on the rear. The C2 had 2 pots on the rear until MY92
No mate....thrashing the GT4 in my avatar pic now. []
timrichardson1
mcgc0
timrichardson1 said:Guys sorry to hijack the thread, my car is a C2 running 2 pots front/rear. I need to change pads and discs all round, what is the best option and where to source with our discount? Seems Textar pads are the way forward, can we go aftermarket on the discs? Thanks
If I recall Tim, I went with OEM Sebro discs from Design911 a few years back. Still good but hen probably have only clocked 10k miles in that time. Textar pads still but have been thinking when they need changing I might give PFC pads a go.
timrichardson1
Steve Brookes
Moderator
mcgc0
When you get the new discs clean them up with brake cleaner and spray paint the hubs (grey/black/whatever) - better than that that brown corrosion look you'll get within months of use.timrichardson1 said:Excellent thanks for the advice sir, it's a 'to do' job that I need to factor in prior to the next annual service in April. Going to have a go at it myself
timrichardson1
Steve Brookes said:Type911 are a reliable supplier for the sebro discs for a 964. The front brakes are 4 pot and there's plenty of pad choice for those but for normal use I found textar to the best. The rear 2 pot brakes use very small pads and there's very little choice for those. It's either Porsche original or textar.
Superb thanks Steve
