hi all,
a few weeks ago, my brake pad wear indicator indicator came on. i presumed it as my front pads (oldest ones) so i booked it in at an indy, they took all the wheels off, but they said could not find any pads that needed replacing (i believe this is the diametric opposite to what an an OPC would do
). they gave all the wires a wiggle and said they thought it was just a loose connection somewhere. this appeared to be confirmed when i mentioned that the light would come on even if i hadn't pressed the brake pedal.
lo and behold, the light went off and stayed off for a few weeks, but has now started coming on again, still sometimes when i haven't pressed the brake pedal.
i just wanted to check that a loose connection or similar is still the most probable diagnosis as i'm going on a track day in a few weeks time and would rather not change the pads unnecessarily.
