Brakes sticking on after washing.
- Thread starter Sylvian
ORIGINAL: tscaptain
Yep. Don't wash it.[]
Despite being the subject of much derision on our register I cover the wheels to stop soaking the discs. The alternative is to give it a good blast with some firm braking. If I did that down my way the car would need washing again...[]
I'm the same, a quick blast down my way in the winter would make the car look like it had not been washed in the first place.
kasspa
Alternative as tscaptain says is to cover wheels but then you dont get alloys cleaned inside & out.......
hth
I take them off every other wash to do that bit - sadly....[&:]ORIGINAL: kasspa
Wash car and wheels
Take car out for a drive to dry brakes
(Get carried away enjoying driving lovely clean car)
Come home with horrible dirty wheel innards from all the crap that came off the wet brakes, fresh brake dust on the wheels, blackened exhaust tips, various bits of grime all over the car etc.
Repeat.
Half seriously, it is worth being OCD about fully drying the brakes before you put the car away and leave it parked without the handbrake on, the brake discs are made of instant rust and corrode quickly, the inner surfaces are particularly prone and you can't see them.
If you get some decent wheel wax protecting the wheels you can dry off the brakes with a quick drive after cleaning the car then just give the wheels a wipe with a microfibre cloth.
I had a Boxster and didn't go for the drying run, come 3 years needed new brakes. Lesson learnt
Air blower is pretty useless (tried that option!) I use some cheap vinyl 4x4 spare wheel covers. You could manage with just the one if you don't mind moving it around the car as you go!ORIGINAL: Sylvian
Does an air blower help? Ts what do you cover the wheels with?
kasspa
[/quote]
It's not that sad..... as I have taken mine off a couple of times for a thorough clean....
But as Rob says it's a vicious circle as you come back with brake dust all over your now not so shiny wheels[
BartyB
Left overnight from yesterday, my Spyder discs are visibly rusty. In all likelihood it may well not turn a wheel for the next 2 weeks. The rust will continue to rust. If I dry the brakes before putting it away, I can leave the car as long as I have to without any signs of the discs rusting.
You will massively extend the life of the discs if you look after them, I learned the hard and expensive way with my 996.
vitesse
Now don't go rubbishing posts by R18's venerable legal eagle-he'll get a cob(web) on-you must also realize that once upon a time BC(in this context-BA--before Arachnid ) he was virtually unknown-but now he's star of PCGB directors,Forum et alia(a bit of Latin since you seem to be familiar with it) -ney over 4500 hits-anyway starting the engine to move out of the garage,then again to replace after washing,surely a few more minutes to dry off the brakes helps on both counts-these old wife tales of enhanced bore wear are surely a thing of the past.[
Steve Brookes
Moderator
vitesse
I agree generally with that approach--perhaps you can clarify something for me because I've never bothered to find out or research the matter--in my experience brake drums & discs have always been made from cast iron for the basic reasons of effectiveness/cost & of course because of the high carbon content,rust resistance compared to steel.
So,whilst being wet does produce a little surface rusting -FeO2-iron oxide,it doesn't generally lead to any significant corrosion,even when left wet.except salt plays havic setting up electrochemical cells.
However,I keep reading bits on here & in mags about steel discs & this is why more modern Porsches get the (particularly) inside disc corrosion talked about--is this the real reason?
ORIGINAL: BartyB
At the expense of knackering the engine doing a short run just to dry the brakes out presumably? And as it happens, I don't think 40k miles on the front discs is a particularly short life so for me drying out the brakes after washing is complete nonsense.
Don't sit on the fence, tell us what you really think [
I agree it's different for a daily driver. Putting a wet car away in the garage and then not using it will accelerate disc corrosion though.
Colin I've used google translate but I'm still struggling [
Steve Brookes
Moderator
ORIGINAL: VITESSE
Steve,
I'm no wiser about the reasons than the next man. Why they corrode so badly on the inside faces and yet the outsides remain almost perfect is hard to understand. My best guess is that (despite the shields) the insides get pebble dashed constantly by road grit, pit and become more prone to corrosion where as the outsides are protected by the wheel spokes. [&:]
Steve, I have a theory that the the brake discs are actually made from compressed iron oxide..! Well, PCCB are made from carbon (fibre) aren't they?
But seriously, I think that using the car every day - as you do - is the best way to minimise the dreaded disc corrosion problem. Then they only wear out.
Jeff
