If you don' t drive in the rain there is no need to read further.
When driving about in the rain, in particular where you are following other vehicles, such as on the M3, I have noticed that the feel of the brakes changes significantly.
When you press the pedal the same amount as you would in the dry, there is a lot less braking effect.
You need to stand on the pedal quite hard to get them to work.
Although when you do stand on them, they work well. It is just that the pedal travel is much more.
I assume that this is since the air ducts are directing spray onto the dics, or they are getting wet some other way.
I have never noticed this on other cars before.
In the dry, and after the wet spell, they work fine, so it is not sue to any wear or setup problem. In the dry they work better once you have braked hard a couple of times and warmed them a little.
Has anyone else noticed this wet weather behaviour? It is a little off-putting, but I guess I just need to get used to it.
I wondered if the ceramic brakes do the same, but I doubt anyone will know.
