Does anyone know? Got a broken switch on one of my 968s aircon. It won't stay locked on. Being told it is only possible to get as a whole unit, the switch isn't available separately. Cost maybe £790 plus VAT. And more than likely a tiny piece of plastic in the switch is broken. Wondering if anyone has any knowledge or can source the part. am posting here because the switch looks identical to that on my 944. Thanks much
Broken aircon switch 944 or 968?
- Thread starter markbeech
bmnelsc
http://www.paragon-products.com/Air-Conditioner-Control-Switch-p/pp944.653.922.00.htm
These guys list both the control unit (complete as described above) and the AC switch only for US$146. Can't tell by looking at the picture if this switch fits into the control unit or if it is for a different set up.
Chrishazle
There's a thread on 968uk where a member did a DIY aircon install and may be able to help - and as you have 2 x 968's, that's a forum you should join, it's much more active and with a lot more info than the 968 forum on here, sad I know but it's down to the history of the 968 register on here despite the current RS's efforts to resurrect the register.
If you're up for a day out, we're meeting at Goodwood race Course tomorrow (Sat 5th Aug) where you can actually talk face to face with owners!!
Kongsodoken
If it's a later 944 or 968 one then it's easy fix just pulls out
early ones are soldered in
did it in my build thread .......buy the switch from OPC
bottom of page 28 shows how it comes apart
http://www.tipec.net/_forums/viewtopic.php?f=25&t=11696&start=405
