I was bleeding the brakes on my 996 Turbo after the Anglesey Track day. However all the inner bleed nipples seem to be seized, I tried WD40 over a couple of days but eventually broke one. Obviously the OPC service lot have only been bleeding the outer nipples which work OK.
I will be replacing discs & a brake overhaul over the Winter, so has anybody any suggestions for exacting the nipples? I have done plenty on steel calipers with screw extractors or drilling out, but not expensive Porsche Calipers! I presume it will be steel nipples in Alloy calipers?
(Alternatively do I need to use these bleed nipples at all and just use the outer ones?)
Thanks, Stephen
Thanks, Stephen
