Build date? RR speakers size . . .
- Thread starter Guest
Although it is actually Beakys birthday tomorrow (1st registered 23/12/87) he is an '88 model according to the chassis number and specification.
If you do a long range search on the forum you should be able to bring up the method of determining the model year from the chassis number, otherwise I'll dig it out for you.
ORIGINAL: 2alexcoo
siddus74
The model year of your car can be found from the 10th digit of the VIN number. This will range from C (1982) to M (1991). .....
It can, but you need to know the format of the VIN number in order to establish which letter you are looking at. As I said earlier, it's in the forum somewhere. [
ORIGINAL: 2alexcoo
For clues to an exact build date, pull out the cubby underneath the stereo, it will have a date and year stamped on it.
That will tell you when the cubby was made. Possibly a few years before the car was assembled! (although more than likely a few months). The German standard (in fact now a general plastics standard) is to have the DIN wheel in all plastic parts where it will fit.
If you want the exact time and date, I think (and I'm sure someone will correct me if i'm wrong) the PCGB will do the legwork through the Porsche files and tell you exactly what you want to know. It costs of course......
