C2 tip stalling
- Thread starter redbaz
If a 98 or 99 it might be the idle control valve, or it may be the MAF. Not sure why it only does it in reverse though.
Will get those two items checked out thanks again.
ps How do you check MAF sensor?
steveoz32
My crank sensor failed but only when warm would it cut out, it gradually got worse. It took me a while to diagnose as it corresponded with low fuel the first time it happened, and I thought it was a fuelling issue for sometime while I checked out all of those components.
Is there some sort of safety feature where the tip won't engage reverse while the car is moving forward? If the CAS / speed sensor is faulty perhaps it thinks the car is still moving? Just a guess.
