C2S Oil Temerature and Pressure Gauge
rjs993
The oil temperature gauge has stopped working on my C2S. The sender unit has been changed and everything points to the instrument itself being faulty. This presents two problems!
1) Where to go to get it repaired or replaced - replacement could be new or secondhand I guess.
2) The C2S has a silver/grey colouring to the rim of the gauge which as far as I know is unique to the C2S ... so clearly I would want to match things up and a standard black gauge is therefore probably not the answer.
My guess is it is best to get it repaired but where to go - and what might it cost?
Robert
[link=http://www.fvd.de/de/en/Porsche-0/964-11-20/cabrio/1992/group/show/VID_12114260-VCD_66357768-gid_73-sort_4-display_50/Gauge_Faces.html]FVD[/link] Try the above link and about 3/4 way down you'll see what you need. I'd give it a try myself 1st. Use a screwdriver to gently prize the rim away and replace the part. That way you can keep all your parts like the gauge face and bezel.
