C4 buying advice requested
- Thread starter 2.4te
Elliot Davies
sorry for shouting [] but it could be wise as these cars can cost ££££££££ if not correct
kevin
completely agree with Eliot, PPI with independant specialist, and then barter on price accordingly, then if ok HPI or similar for Vcar and finance stuff, cost around £200 or so tops.
Check turrets for creases, check windscreens front and rear for rust, check vin plate for scruffy appearance (shouldn't be a shiney paint job) check everything works properly, simple but yes people forget to, brakes in a straight line, 10mph in 2nd gear, floor it, should leap off like a scalded cat. 3rd gear accelerate, 4500rpm should kick again (vacuum operated mainfold plenum should open) distributor vent kit, clutch replacement, DMF (freudenburg or LUK?) oil leaks from cyl head barrel joint. non-standard parts. good tyres (not some Korean makes) oil pipes from filter, through right rear wheel arch should be on good cond. VIN no: check is it really a 91 C4? should be a plastic intake manifold.
thats it from memory
Kevin.
