mcgc0
Bit of a funny one this one...
From cold, ignition on and can hear the boost pump etc doing it's noise stuff until up to pressure. Start engine and after a few seconds all warning lights go out (ignoring parking brake) - all except the 4-wheel drive PDAS and the ABS lights. Still stationary. Wait a further 1+ minute and both lights still remain on. No warning buzzer (as I haven't started moving off yet). Fluid reservoir at max btw.
Start moving off and continue to drive thinking maybe wheel speed sensor or diff locks related, both lights remain on with no warning buzzer - hmm... However, start to get up to speed (50+mph) and they go off. Ah, must be speed related me thinks. But, when stationary at lights they still stay off and the problem doesn't reoccur for the rest of the journey. Confused me for a while during the course of a few short test trips - each producing the exact same results.
Ah ha, today and getting closer to the issue (I hope); discovered now that it isn't wheel speed related - it's engine revs!?! Stopped off after a short run where the lights had eventually gone out as before. Restarted engine and both lights back on again - damn! However, blipped the throttle while stationary to 3k+ rpm and both went out [&:]. Able to faithfully reproduce the same result each and every time. Happier now that the problem is consistent under the same test condition but of course non the wiser as to root cause - Instrument gauge? Relays R34 (ABS) or R51 (Brake Boost Pump)? Fuses?
