C4 Re-mapping
964rh
Hi
After the dyno session in July I'm thinking of having the C4 re-mapped (not chipped) and wanted to know if anyone else apart from 9M does this?
Would take to 9M but cause I've got a C4 you have to use another rolling road at extra cost (£100-150).
Can anyone recommend someone (pref. in the middle of the country) who can do this?
Rob
Rob,
At the risk of stating the obvious, I was fairly sure that Weltmeister will do it. It's worth a call to Allan anyway.
At least that would have the advantage of giving you a fairly meaningful "after" run to compare with your "before" - if you see what I mean.
Dave
Hi Rob
If I were getting mine done, the only guy I would use is Wayne Schofield of Chip Wizards. He has been very highly recomended by several people and I have seen the results of his work - very honest about what can be achieved and dedicated to his work. He is based up north somewhere so you would have to go to him or if he has enough work I understand he will make a trip to a local dyno - he may even be able to use Weltmeister.
Don't worry about the dyno though, any decent place will need a dyno to optimise the map and will offer before and after results to demonstrate what they have achieved as part of the work.
Let us know how you get on.
