When adjusting my handbrake I wondered what was beneath the small rubber access "plate" in the transmission tunnel cover (behind the handbrake and under the cassette case/trinket tray). So of course I managed to lose the rubber cover into the transmission tunnel [
Easy job to remove the panel under the car and retrieve it, and I took a few photos whilst I was there. I found two things:
1) Perished gaiter around the U/J on the front wheel output drive shaft. Does anyone know what is involved in changing this ? Can it be done by breaking the shaft at the flexible joint, or is it engine and gearbox out/move ? I sometimes get a faint but annoying delayed "clunk" shortly after drive take-up in 2nd and 3rd and suspect it's coming from the FWD shaft U/J...
2) A rubber/plastic pipe with 4cm diameter rubber spacer (see arrow in first pic at link below) was floating free in the tunnel and could touch the drive shaft ! However, there was no evidence of rubbing. What is this and should it be flopping about ? I fitted a single tie wrap to constrain it slightly so that it can't touch any rotating parts.
Photos: http://picasaweb.google.co.uk/robert.slade1/993C4TransmissionTunnel#
