dave993cars
Hi All
Need help, I have had my C4S outside instead of in the garage as my daughter was using the garage to work on her pride and joy (Mk2 Golf) having stood for well over a month I decided to start it, when I started the engine I noticed the rear wiper was working but it would not switch off, at the same time I could smell an electrical burning smell, I turned the engine off right away and disconnected the battery, checked all fuses (none blown), I removed fuse No 28 (rear wiper) reconnected the battery and started the engine (no rear wiper working) but I now had no heater control, switched off disconnected the battery, and removed the heater unit, as you can see it was the unit that had shorted I presume ? is this a known problem, two questions, would the wiper motor be linked to the heater problem, and secondly can these units be repaired or is it a new (or S/H) and if so where, thanking you in anticipation of some help.
