MJL944
Hello all,
On removing the long plastic trim above the glove box (in order to remove and repair the digital clock) I found that there was a plastic plug over the cabin air intake hole that is behind the small rosette grill to the left of the cigarette lighter (see photo 1 below). I can push this plastic plug out very easily using a biro (see photo 2 below).
Should that plastic plug be there?
If so, why is it there?
The pipe that connects up behind that hole joins to the little cabin air intake sensor and fan unit behind the glove box so I don't understand why there would be a plug there as surely this would stop cabin air being drawn through the pipe towards the sensor.
Many of you will have taken off the trim in this area so did you all have this plug or should I remove it? I've ordered a new long trim piece as my current one has a small crack in it but if I don't need the plug I won't transfer it across to the new trim.
Many thanks.
Many thanks.
