Just a post to get my fears confirmed as I doubt they will be dispelled.
Was taking my son to school this morning when we both noticed it was unpleasantly hot in the cabin of the car.
Adjusted the climate control unit to cold - nothing happens. Twiddle the dials and move the knobs - no change in anything at all. Then I notice there is not a sound from the fans whatsoever. Press the windscreen demist - zero response. Rear blower fan not operating either.
Boll***s. CCU is busted I think. That's not good.
Check all the fuses - rear fuse box 30A - good
Front fuse box - Fuse no1 - 25A blown! - hooray I think problem solved and a 8p fix!
Restart car. Fans are on at position 0,1,2 and 3 but then stop dead. Check fuse again - blown - s**t. Replace it again. Restart CCU on 0,1,2 - fine. Drive for 30 miles no problem. Fans in the cabin working fine. All servos working hot air, cold air, air in the footwells only and air to the screen only......... Right press the demist button - high speed fans and then dead. Check fuse - blown.
I guess this means that one of the front cabin fans' bearings has died and whilst the fan motor is happy to cope at low speed at high speed the current draw, due to the resistance against the motor, is so high that it blows the fuse.
So replacement fans is the cure I think. £500 each or £250 2nd hand and likely to be worn. Don't think it is worth replacing just one and I don't fancy replacing with a 2nd hand fan as it is likely to be FUBAR too.
Having looked at the various threads I really don't fancy the time and effort involved in removing and dismantling the fans/motors to replace the bearings and or the fan motors.
Whilst I love this car. I really really do hate the prices of some of the parts.
Any other thoughts?
Any other thoughts?
