Cabin temperature sensor
- Thread starter j7agy
Pull off the cover plug (20). Undo the 3 torx screws (21) - one is hidden in the recess where you pulled out the plug.
Gently pull the vent from the dash to reveal the sensor (24). Squeeze the clips together as shown in the bottom illustration, and the sensor will come out from the back. Unplug the connector (23), and you are done.
chriscoates81
j7agy
Thanks again,
John.
If you have a pre02 model year, you may be able to interrogate the value by using the climate control hack.
KR Lee
chriscoates81
chriscoates81
j7agy
Cheers, John.
