Two things now causing regular [
]problems with the roof:
( The roof head motors have been changed under the recall at some point in the past )
1st one is just alarming - the roof seems to close fine up until it's at about 1o'clock - just past vertical,
then it seems to almost fall / speed up - so it sometimes slams down onto the head of the windscreen[
that was the lesser of the problems!!!![
Worst one is the head locking motors ( that clamp the roof down onto the top of the windscreen ) seem to have given up the ghost - and now I have to resort to locking these using the scredriver slots - takes ages.
When you push the button to open the roof - the head clamp motors are fine - and 'pull-back / open without problem![8|]
This fault has been around for a while - but only off and on - without any consistency?
I've tried lubricating the roof to windcreen motors, and the 'trigers / switches on the leading edge of the roof.
Anyone any ideas about other areas to check / fix / replace??[8|]
TimP[&:]
TimP[&:]
