Anyone know if you can get replacement trim clips for the rear "parcel shelf" on a 944 cabriolet. I presume they are the same on a 968 cab? I mean the grey cover thing that goes over the hood motor under the rear window. There are 4 hidden clips undeneath that are made of a white plastic and are sort of serrated push in design. I cannot find the area on the downloads of PET i have found online
My trimmer broke one completely and damaged three others so the shelf does not fit tight to the bulkhead, and when the roof is down, it pushes the window fold against the mohair of the hood and leaves little inprints in it, (from the mohair weave) that need heating and polishing out, or it leaves a dull line across the screen when up!
Annoying as they have just been a bit cack handed.
The reason I ask if they are removeable, it without fully removing the trim peice yet, I cannot actually see if they will pop out of the trim, they seem pretty stuck in there, and dont appear to "slide in" like the door trim clips etc.
Anyone managed to repalce these things?
