Calibrating the Speedometer
- Thread starter John Ware
The speedo will be colour coded, with a green zone, an orange zone, and a red zone.
The green zone will be for in towns.
The orange zone will be for out of town (if there is any given the amount of building there is), where there are orange signs. This gets round the fact that a significant number of people do not understand the national speedlimit signs and the general concept.
Then there will be the red zone, which will cut the engine management, pull you over the to side, use the car phone to call the police giving your location from the sat nav. You will then be given electric shock therapy and have all you worldly posessions confiscated.
The speeds will be dynamically changeable by satellite system, allowing the speeds to be changed by local councils, busy bodies, the time of day, the weather conditions and whether a bit more revenue is needed this month.
Tampering with the system will block the engine management for 6 months forcing you to ride your state provided bicycle (which due to Government inefficiencies costs twice as much as if you just bought it yourself).
A brand new tyre has a circumference 40-45 mm larger than one with a minimum legal 1.6mm of tread (assuming a new tyre has about 8-9mm of tread). This equates to about 2% of the overall circumference of an 18" wheel fitted with a 265/35, which is about 2 metres. So that's 2 mph at 100 then. If your tyres are at the wrong pressure, they will bulge at high speed (they do anyway, but this is largely what the speed rating stuff relates to, I believe) further increasing the circumference, and so reducing the indicated speed.
Porsche knows this which is why their designers position the speedo completely out of view, instead preferring you to pay attention to your tacho, which is far more important anyway!
In my experience, if you think you may be driving too fast, you generally are.
I was chatting to a serving Met. traffic division officer recently, and he was expounding a theory employed by his colleagues that everyone gets done for speeding in town at 45 mph because that is the slowest you can comfortably drive in top gear in an average car these days!
Something to do with the way we were taught to drive - 'Get the car into top gear as soon as possible'. In 1970 a Vauxhall Viva was doing about 25 in top (that is 4th gear).
Doesn't explain automatics though.
Also, your GPS cannot be that accurate, can it, as it can only postion you to within 15 feet?
John Ware
Some interesting thoughts though....
