random hero
Any one got a pair for sale so i can fit my 928s4 brakes onto my 220 hubs ??
ORIGINAL: DivineE
Nope but tell me if you find a cheap supply. Otherwise its easier than people would have you believe to stick on a set of late turbo hubs in complete form. Specify 89' on if your buying from a breaker though otherwise you might end up with the same size brakes!
Ive managed to get a new pair of brackets from a guy on the 968 forum , all being well i should get them on tuesday. John where is the rubber boot as ive looked on my turbo and s2 and cant see any boot that comes anywhere near the disc ??ORIGINAL: John Sims
If having brackets fabricated I would also highly recommend having shims manufactured to fit between the hub and the disc. This will help offset the disc an avoid it abrading the steering knuckle rubber boot. 4mm should be ideal.
