Today I decided I would flush through the brake system fluid.
I did all the service items at the end of last year but decided to leave the brake fluid flush until the fine weather.
Two minor disasters occurred whilst doing so.
BLEED NIPPLES
I started at the nearside rear and found the nipples very very tight (system should have been flushed two and a half years ago, that last time I paid for a service so that was when the nipples should have been last eased off & tightened).
Outer one eventually freed but the inner one sheared off before any movement.
From then on I removed the captive bleed nipple caps and soaked with PlusGas before attempting to back off the nipples.
With great care and gently applied force I eventually got all the others to back off but they were all very tight and could have sheared if too much force was applied too quickly.
I think the rubber loop of the captive caps do not help as they retain water at the top of the threads beneath the 11mm hex flats.
QUESTION ONE - does anyone know the thread size and thread length of the bleed nipples?
On my Mtsubishi FTO I have replaced the mild steel nipples with stainless steel ones so the threads will never corroded and seize into the caliper with the risk of shearing off.
At the moment I do not intend to do anything with the sheared off nipple, it does not appear to have moved before it sheared and is not leaking.
Bit of a pain I would imagine to remove.
LOCKING WHEEL NUTS
Obviously I had to take the wheels off to gain access to flush the brake fluid.
My OE locking wheel nut key failed about six months ago so I bought a new one from Porsche.
That one today is on the verge of failure.
I take my wheels off 2-3 times a year to fully clean & wax but since I have bought the new wheel key, today was only the second time I have used it.
So am now looking to replace the OE locking wheel nuts/key with an aftermarket set that can withstand the normal "run-o-the-mill" forces required to take the wheels off and put back on, which obviously the Porsche design of lug/key cannot.
QUESTION TWO - can anyone recommend some aftermarket locking wheel lugs.
BLEED NIPPLES
LOCKING WHEEL NUTS
